April 11, 2014, 05:16 |
UDF for Heat Flux
Kishan Kumar Jaiswal
Rep Power: 12 |
Dear all,
I am trying to write udf for heat flux having the formula Q = 0.304/y*y*y but I am unable to do it. It always shows some error. Can anyone write udf for heat flux. y is the length. and Q is the heat flux acting on X-Y plane in Z direction. Geometry is a cube with dimension 10*5*0.005 all are in meters. Thanks. Last edited by kishan kumar jaiswal; April 11, 2014 at 07:18. |
April 11, 2014, 10:08 |
Flavio
Rep Power: 16 |
Hello kishan,
is this a boundary condition? In this case I suggest reading Fluent UDF Manual about DEFINE_PROFILE. Regards
Bionico |
April 14, 2014, 02:01 |
Flavio
Rep Power: 16 |
can you post your UDF, please? Regards
Bionico |
April 21, 2014, 18:01 |
Rep Power: 12 |
Dear friend,
There are some changes introduced in the formula, right now it is Q(Y) = (0.304)/(deltaY + deltaY/2)^-3 Where deltaY = 50cm and Y = 10m Y is the length on Y-axis and X whixh is equal to 5m is length on X-axis. Q is heat flux apply on the X-Y plane towards the Z direction. Geometry is a cube with dimension 10*5*0.005 all are in meters. If possible please help Regards, Kishan |
uds flux - drift velocity - udf | johnwinter | Fluent UDF and Scheme Programming | 3 | November 25, 2017 04:07 |
UDF Mass flux computing | Carlo | FLUENT | 6 | November 23, 2014 21:59 |
UDF for heat flux applied during T seconds | nazeem | FLUENT | 0 | June 22, 2004 05:26 |
UDF for a heat flux applied during T second on a w | nazeem | FLUENT | 0 | June 12, 2004 10:28 |
udf for transient heat flux BC | isaac | FLUENT | 1 | June 3, 2004 16:29 |
