Flow through concentric pipes carrying different fluids |
Deepak
Rep Power: 0 ![]() |
Hello Everyone,
I am beginner at fluent. I have assignment which of course I couldn't solve. So asking here. Problem: Flow through two concentric pipes is vertically upwards. Air at 30 deg. C. flows through outer pipe. Water at 30 deg.C. through inner pipe. Heat generation of 0.5 kW at the center of inner pipe. Transient condition. Assume other required data such as length and diameter (general flow problem). Show: 1)Draw temp. profile 2)Velocity profile Please give me the procedure to solve it in fluent. Refer attachment for the problem description. |
fluent, heat transfer, laminar flow, turbulence and laminar |
Modeling a two phase flow in a concentric cylindrical geometry | rshbhb | FLUENT | 4 | June 30, 2021 16:42 |
Flow Between Concentric Cylinders | larscliff | ANSYS | 0 | February 17, 2011 04:43 |
Can 'shock waves' occur in viscous fluid flows? | diaw | Main CFD Forum | 104 | February 16, 2006 05:44 |
Question on 3D potential flow | Adrin Gharakhani | Main CFD Forum | 13 | June 21, 1999 05:18 |
computation about flow around a yawed cone | Tylor Xie | Main CFD Forum | 0 | June 9, 1999 07:33 |
