Contours of Swirl Strength in Fluent
Old   April 5, 2014, 11:57
Default Contours of Swirl Strength in Fluent
Abhi
abhinav.abhi19 is on a distinguished road
I am working on a problem of Tip Leakage Flow in a Low Pressure Gas Turbine Airfoil. My cases are at Low Reynolds Number. Due to the complexity in the Endwall Region I am using Transition SST Model and finer grids. I am running Transient. I got the results for Pressure Distribution and Total Pressure losses and it matches well with the experiments. I am using Velocity Inlet and Pressure Outlet Conditions. Turbulence properties TuI and Hydraulic Diameter is defined at the inlet and I also specified the Velocity Profile at the inlet.
I wanna plot the contours of Swirl Strength and I know it is defined as defined as the imaginary portion of the complex eigenvalue of the local velocity gradient tensor. I can get the Velocity Gradient Tensor by defining Q = 0.5(Omega ij*Omegaij -Sij*Sij). I do not know how to plot Swirl Strength or how to define it using Custom Defined Functions.
Please help...Thanks
abhinav.abhi19 is offline   Reply With Quote
contours, fluent 14.5, swirl strength
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 23:56
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 10:28
Fluent manually contours Range selection Qazi Tanveer FLUENT 0 July 6, 2012 04:23
regarding the gas concentration contours in fluent sandyouct FLUENT 0 June 15, 2011 12:40
Master node in parallel computing only distirubtion syadgar FLUENT 1 September 8, 2009 17:41
