higher turbuelnt intensity in helical coil
Old   March 26, 2014, 03:06
Default higher turbuelnt intensity in helical coil
Jassa
jassa28 is on a distinguished road
hello, I am simulating flow and heat transfer in a 2 turn helical coil using k-e model with Inlet velocity is 0.8 m/s and diameter is 20mm while pipe coil diameter is 200 mm.the velocity BC is on inlet with 4% turbulence intensity and 0.006 hydraulic diameter. Pressure BC is imposed on outlet with 4% turbulence intensity. i m facing the problem regarding higher value of turbulent intensity . the range mentioned is 0.0124 to 0.134 bt the value lies exactly at 0.134 which is higher. kindly give some suggestions.
jassa28 is offline   Reply With Quote
helical coil heat exchanger sarsam.9296 FLUENT 3 January 14, 2016 04:02
Problem with Periodic Boundary for helical coil nilhas FLUENT 0 January 2, 2013 02:26
Periodic Boundary for helical coil nilhas FLUENT 1 December 28, 2012 12:35
Problem making a periodic boundary in helical coil Mikael FLUENT 0 January 24, 2008 11:22
Gambit helical coil creation Antonio FLUENT 4 January 22, 2003 17:18
