Moment coefficient
Old   March 20, 2014, 10:30
Default Moment coefficient
JaC
Jakub Broukal
JaC is on a distinguished road
I am performing an unsteady simulation of an impeller and I would like to know the torque on all of the impeller blades. So far I am using a single moment monitor, with the axis defined as the impeller axis, which gives me the moment coefficient.
My question is as follows:
How do I get the real torque from the coefficient?
In the Fluent UG i found the formula
Moment_coef = Moment/(0.5*ro*v^2*A*L)
Where do I take these values from? Are those the reference values? Or should I get a monitor for each blade separately?
Thanks
JaC is offline   Reply With Quote
momentum coeficient
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
calculate pitching moment coefficient jyh3134 FLUENT 0 January 30, 2013 11:40
UDF extern variable - mean time moment coefficient enry Fluent UDF and Scheme Programming 0 November 14, 2009 07:56
UDF extern variable - mean time moment coefficient enry Fluent UDF and Scheme Programming 0 November 14, 2009 07:51
Automotive test case vinz OpenFOAM Running, Solving & CFD 98 October 27, 2008 09:43
