two questions about using the ANSYS Fluent
Old   March 19, 2014, 23:08
Default two questions about using the ANSYS Fluent
liu_zh_w is on a distinguished road
hi,
i have two questions about using the ANSYS Fluent :
1 . could i realize the dynamic mesh by my own code without smoothing/layering/remeshing? and what should i do?
when the deformation is too large, the remeshing method always doesn't work as the negtive volume ?
the delaunary graph mapping is an impressive apporach to handle this question according to some papers,
but how can i couple the powerful solver(fluent) and the notion of dynamic mesh? by udf?
2 . could the fluent calcucate different zones by different models in only one case?
the question is induced by the calculating the inner flow of a balloon.
inside the balloon, it is natural convection which is conducted by temperature, it can be calculated by density-based with ideal gas model; however, out the balloon, it is the flow canbe calculated by S-A or SST model by pressure-based models.
but the external and inner fluid effect each other by heat transfer of balloon shell.
thank you very much for your answers.
sincerely
liu_zh_w is offline   Reply With Quote
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 04:22
prePDF preprocessor in FLUENT (ANSYS 12 version) anee Fluent UDF and Scheme Programming 7 March 18, 2013 23:57
Fluent v6.3.26 better than Ansys v12.1 jemyungcha FLUENT 2 August 25, 2012 00:10
FLUENT to ANSYS Temperature Mapping Procedure schreiberc1 FLUENT 0 June 29, 2006 14:50
import Fluent data&case to ANSYS Vlad S FLUENT 0 April 2, 2003 06:49
