Overshooting static pressure
Old   March 18, 2014, 02:19
Default Overshooting static pressure
Naunidh
guns_down is on a distinguished road
I am modeling a flow through a channel such that the flow enters radially, travels axially along the length of the channel and then exits radially. This is part of my work on heat pipe modeling in Fluent and I have used a 2D axisymmetric geometry. Now I know the mass flow rate at the inlet & exit as well as the inlet static pressure. My aim is to get the axial pressure variation and so I read that if u use the pressure outlet condition then u can specify the static pressure and the target mass flow rate. So I used the pressure outlet bc at the inlet and the mass flow inlet bc at the outlet. However my static pressure at inlet is overshooting the specified static pressure of 8.57 bar ?? Any reasons why this could be happening & how to possibly correct it ??
guns_down is offline   Reply With Quote
mass flow inlet, pressure conditions, static pressure
simple model, difficult outlet Eric CFX 7 May 23, 2014 09:13
Maintaining Static Pressure at Fluid Flow Inlet cdevalve FLUENT 3 January 14, 2012 01:11
How to achieve constant static pressure in inlet? Zou Jianfeng FLUENT 0 October 21, 2008 02:55
Setting static pressure as the inlet BC ruined FLUENT 1 March 21, 2008 15:57
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
