rotating disk in a cylinder
Like Tree1Likes
Old   April 2, 2014, 02:33
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
define your rotor domain as rigid body, then ou can give the angular velocity as a profile in the "motion UDF/profile"
https://www.sharcnet.ca/Software/Flu...am-solid-kinem
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   April 2, 2014, 15:05
b. singh
bhanu is on a distinguished road
max can you show me the way from the beginning?? i mean how to setup a udf/profile cause i have tried to but there is nothing happened..
bhanu is offline   Reply With Quote
Old   April 3, 2014, 01:50
anbu
anbu2cfd is on a distinguished road
can you send me your geom file in step or iges format, to my mail id. so that i can check and try to help you. mail id is anbu1088@gmail.com
anbu2cfd is offline   Reply With Quote
Old   April 3, 2014, 01:52
anbu
if you know the angular velocity of your rotor, then moving reference from will be a good opt for you, instead of dynamic mesh.
Old   April 3, 2014, 02:59
-mAx-'s Avatar
Maxime Perelli
>> transient profile in a tabular format
1. Standard Transient Profiles
The format of the standard transient profile file (based on the profiles described in Section 6.24 of the FLUENT 5 User's Guide) is
((profile-name transient n periodic?)
(field_name-1 a1 a2 a3 .... an)
(field_name-2 b1 b2 b3 .... bn)
(field_name-r r1 r2 r3 .... rn))
One of the field_names should be used for the time field, and the time field section must be in ascending order. The periodic? entry indicates whether or not the
profile is time-periodic. Set it to 1 for a time-periodic profile, or 0 if the profile is not time-periodic.
An example is shown below:
((sampleprofile transient 3 1)
(time
1
2
3
(u
10
20
30
You can read this file into FLUENT using the Boundary Profiles panel or the File/Read/Profile... menu item.
Define >> Profiles...
File >> Read >> Profile...
check omega_x at https://www.sharcnet.ca/Software/Flu...ug/node446.htm
Rotating cylinder raul FLUENT 3 February 1, 2015 06:48
Flow past rotating cylinder: Problem with ForeCoeffs raf1111 OpenFOAM 1 December 16, 2013 10:45
vof rotating disk 2d bene FLUENT 1 October 24, 2010 14:18
rotating cylinder using sliding mesh Tim Daly FLUENT 1 November 10, 2008 00:02
Numerical solution to the rotating disk problem? johny Main CFD Forum 7 September 5, 2005 06:53
