HTC calculation for NGV
Old   March 14, 2014, 08:14
Default HTC calculation for NGV
Ozge
ozgulo is on a distinguished road
Dear all,
I have a problem regarding HTC calculation in Fluent. I have a case of a turbine NGV that has 1.15 Mach max on suction side.
I need to calculate the htc values for constant temperature profile on blade.
The heat transfer coefficients are calculated normally until the shock. But after the shock, htc's drop suddenly to negative.
I tried using different turbulence methods, or discretization methods without success.
What is the reason for this? Is it that fluent cannot solve after a seperation bubble occurs, or is it because of the shock? Is there any way to solve this?
I am running the case 2D for now. I am using mainly Transition SST model altough I tried others too.
Thanks,
ozgulo is offline   Reply With Quote
Comparing HTC between CFX and hand calculation. turbotel CFX 1 March 3, 2011 10:56
MRF and Heat transfer calculation Susan YU FLUENT 0 June 2, 2010 09:46
calculation of htc christopher0 Main CFD Forum 3 April 7, 2010 04:09
Warning 097- AB Siemens 6 November 15, 2004 05:41
HTC calculation kvbswamy CFX 0 August 10, 2001 03:36
