Help Needed for very simple problem {ANSYS Fluent} |
March 12, 2014, 09:21 |
Hi all,
I'm a final year mechanical engineering student and have taken up a project which involves analysis of a simple "rotor in a pipe" situation. I have modeled the rotor and the pipe in Pro E 5.0 and am able to mesh it in ANSYS workbench. Now i'm stuck. I don't know how to set the rotor in motion using the flow. I need to calculate the pressure drop across the rotor and its rotational speed from the analysis. I have the input parameters of mass flow rate and inlet pressure. can someone please guide me through the whole process of setting up the problem in FLUENT in a step by step manner, as i am a beginner. Thanks a million. |
March 12, 2014, 17:04 |
Rafal
Rep Power: 13 |
As You are beginner start from Fluent tutorials. You can also check informations from imechanica etc. like that one: http://imechanica.org/files/fluent_1...ving-parts.pdf
March 13, 2014, 01:35 |
Thanks! will check it out!
ansys, beginner, fluent, new to cfd |
How to open Icem mesh in Ansys Fluent? | emmkell | FLUENT | 27 | February 6, 2018 04:34 |
Interesting problem: Parallel Processor VOF Fluent + Dynamic Mesh + System Coupling | spaceprop | FLUENT | 5 | September 2, 2014 10:43 |
Can I solve this problem by Fluent? | Kai_kc | FLUENT | 1 | October 27, 2010 06:29 |
FLUENT to ANSYS Temperature Mapping Procedure | schreiberc1 | FLUENT | 0 | June 29, 2006 14:50 |
"Memory too low" problem with Fluent HELP NEEDED | Amr | FLUENT | 6 | May 8, 2006 13:06 |
