March 9, 2014, 12:39 |
Axial Velocity Contour in non-planar bend
Omid
Rep Power: 14 |
Hi guys,
I simulated a fluid flow in a non-planar bend in which the inlet and outlet surfaces are not placed in the same plane. The bend consists of two 90 degree bends. I would like to see axial velocity in different sections through the pipe. I could have seen total velocity contour, but my problem is in plotting axial velocity. The axial vector is not along coordinates, but I have the normal vector at each plane. Do you have any idea how to get axial velocity contour via post-processing in FLUENT? Thanks, Omid. |
August 4, 2014, 14:00 |
Ali reza
Rep Power: 12 |
hi omid
I have the same problem.did you find answer? please help me if it is possible |
October 7, 2014, 15:22 |
Rep Power: 12 |
Hi guys,
I am soloving the same thing. Did you find some solution to have the relevant axes for the axial velocity? I would appreciate your answer. |
axial velocity, non-planar bend |
WSS and normal velocity gradient for the slanted pipe | wanna88 | FLUENT | 2 | October 1, 2012 23:34 |
How to draw velocity contours along the bend of U-pipe | mariam.sara | FLUENT | 1 | March 20, 2011 09:12 |
Axial velocity problem | clueless | Main CFD Forum | 0 | May 15, 2009 05:01 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
velocity profile in a 90 degrees bend | Tim | Main CFD Forum | 6 | June 18, 1999 03:58 |
