trouble in SDOF solver
Old   March 9, 2014, 05:23
Default trouble in SDOF solver
vahid Goodarzi Ardekani
vga67 is on a distinguished road
hi everybody,
I have simulated a 3 dimensional problem with SDOF solver and Dynamic mesh of Fluent V.6.3.26. the problem is about the sinking of a solid spherical particle with 5 mm diameter and 1010 kg/m3 density in water. I used the same UDF that exists in Fluent tutorial "falling box" but have changed it so that it can be used in my problem.
the following text is the desired UDF:
DEFINE_SDOF_PROPERTIES(test_box, prop, dt, time, dtime)
prop[SDOF_MASS] = 1.55e-5;
prop[SDOF_IXX] = 2.5e-11;
prop[SDOF_IYY] = 2.5e-11;
prop[SDOF_IZZ] = 2.5e-11;
prop[SDOF_IXZ] = 2.5e-11;
prop[SDOF_IXY] = 2.5e-11;
prop[SDOF_IYZ] = 2.5e-11;
(all of the above units are of SI units "kg and meter")
after 0.2 second with 0.001 time step, the particle moves 50 mm which i think is not logical and it should last longer, since the density difference between the particle and the water is very low. in each time step a message is written which is "the program can not calculate the angular velocity". i know the problem with this message and that is because of the fact that second moment of inertia is less than 1e-6. with the situation i described above, my question is that " why does the particle sink too fast?"
thanks
vga67 is offline   Reply With Quote
thobois class engineTopoChangerMesh error Peter_600 OpenFOAM 4 August 2, 2014 10:52
Unexplained Error during Solver Runs cfb CFX 6 November 9, 2012 16:42
Strange residuals of the Density Based Solver Pat84 FLUENT 0 October 22, 2012 16:59
Working directory via command line Luiz CFX 4 March 6, 2011 21:02
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 15:08
