Propeller Thrust
Old   March 8, 2014, 12:59
Question Propeller Thrust
mahdi sajjadi
mahdisajjadi is on a distinguished road
hi
I'm simulating two propellers rotating in opposite directions in fluent to calculate their thrust.
I used multiple reference frame as a steady approximation of real condition.
I've attached a screenshot of the gambit file. In two small cylindrical frames the air is set a rotational speed in the direction that the propeller should have been rotating and the blades are fixed.
The problem is the final result is almost half of the experimental thrust.
I've used different turbulency models, different domain sizes, different boundary conditions and have almost changed everything but got no better results.
The velocity vectors and pathlines look fine. Even tried it with a 4 Millions cells mesh.the thrust is still half of what it should be.
After the solution is converged I go to Results>Report>Force set the direction to (0,1,0) -which is the propellers rotating axis- select two propellers and read the force. Is this how i should get the thrust? What am I doing wrong? :/
I really appreciate it if anyone can help me. thanks for your time
mahdisajjadi is offline   Reply With Quote
Old   December 1, 2014, 21:24
nvtrieu is on a distinguished road
Hi friend,
I going to simulate a marine propeller too.
But I don't know where I should start.
Could you share me your experience?
Thank so much!
nvtrieu is offline   Reply With Quote
mrf, propeller thrust, quadcopter, quadrotor
Thrust and torque of a propeller Alex H FLUENT 3 July 1, 2016 18:00
Propeller thrust stroccel CFX 7 January 12, 2014 06:52
ship propeller thrust performance analysis burak samsul FloEFD, FloWorks & FloTHERM 6 December 4, 2013 07:18
Propeller Thrust distribution cfd_analysis FLUENT 0 July 29, 2013 07:26
Propeller thrust at diff. advance ratio (CFX 5.7) Zoltan CFX 9 April 27, 2005 09:23
