How to specify static pressure at inlet
Old   March 5, 2014, 03:26
Question How to specify static pressure at inlet
yehanyu
yhy20081016 is on a distinguished road
Hi, everybody.
I'm working on simulation of cavitating flows around hydrofoils in cavitation tunnels. In order to match the experimental conditions, I want to specify static pressure at inlet of the computational domain(corresponding to inlet of the test section of the tunnel). However, by using the "pressure inlet" boundary condition in FLUENT, one can only fix the total pressure at the boundary, while the static pressure is allowed to float. Can you suggest a convenient solution to this problem? Thank you very much.
yhy20081016 is offline   Reply With Quote
Old   March 5, 2014, 07:30
Nick Prendergast
neprendo is on a distinguished road
total pressure = dynamic pressure + static pressure.
dynamic pressure= 0.5 * density * (velocity^2).
So long as you don't have variable velocity or density at the inlet, those should work.
hope this helps.
Nick
neprendo is offline   Reply With Quote
inlet boundary condition, static pressure, total pressure
Pulsatile pressure inlet with pressure outlet a.lynchy FLUENT 3 March 23, 2012 14:45
Maintaining Static Pressure at Fluid Flow Inlet cdevalve FLUENT 3 January 14, 2012 01:11
How to achieve constant static pressure in inlet? Zou Jianfeng FLUENT 0 October 21, 2008 02:55
Setting static pressure as the inlet BC ruined FLUENT 1 March 21, 2008 15:57
Pressure Inlet yields wrong velocities Ben FLUENT 0 November 21, 2004 02:47
