parallel running issue in ansys 14 fluent
Old   March 5, 2014, 02:05
Question parallel running issue in ansys 14 fluent
adnan aziz
ade4921 is on a distinguished road
hello,
i am trying to run ansys 14 fluent in parallel mode on one PC only. following is the problem:
-when i click on the parallel option, i define no processors as 4.
-fluent starts running and then gives the following message:
"Unable to open HKEY_LOCAL_MACHINE\SOFTWARE\Intel\MPI\SMPD\process \4600 registry key, error 5, access is denied"
can someone please help me what does this mean and how should i solve it?
Thanks
ade4921 is offline   Reply With Quote
Old   March 5, 2014, 06:18
ghost82's Avatar
Rick
ghost82 will become famous soon enough
Try to start fluent with admin priviledges: right click on icon fluent and click on "run as admin" and see if the error goes away.
Daniele
ghost82 is offline   Reply With Quote
Old   March 6, 2014, 03:40
Default Thanks bro
adnan aziz
tried it and it worked.
but another issue has come up.
the simulation that i am trying to run in parallel is taking far too much time, in fact its still running while i write this. whereas the same simulation converged in half an hour in serial mode. can there be a reason that iam not looking at?
thanks again
Old   March 6, 2014, 06:35
Nick Prendergast
neprendo is on a distinguished road
It could in theory have something to do with the amount of available memory on your computer. If you run out of RAM the processes start to run on the harddrive which would much slower.
neprendo is offline   Reply With Quote
parrallel running fluent
ANSYS CFX 14 on UBUNTU 12.04 64bit: PARALLEL ISSUE david.pasquale CFX 7 July 15, 2024 14:43
Problem in using parallel process in fluent 14 Tleja FLUENT 3 September 13, 2013 11:54
The monitor is flashing when running ANSYS FLUENT nvtrieu ANSYS 0 May 3, 2013 04:02
Hardware for running ANSYS Fluent 12.1 ngj_22 Hardware 2 September 29, 2010 08:26
running multiple Fluent parallel jobs Michael Bo Hansen FLUENT 8 June 7, 2006 09:52
