low reynolds number turbulence model in FLUENT
Old   March 1, 2014, 08:21
Default low reynolds number turbulence model in FLUENT
shubham jain
shubham jain is on a distinguished road
i have done analysis on naca0012 with Re=3e6 using k-e RNG.
But i want to know best turbulence model for low reynold number analysis (well below critical reynolds number).
should i use spalart allmaras or some other model??
and upto which reynolds number should i use k-e RNG and then shift to Low Re model??
shubham jain is offline   Reply With Quote
Old   March 1, 2014, 08:49
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Low Reynolds number turbulence models should not be confused with low reynolds number flows.
Low reynolds number turbulence models are intended to resolve the viscous sub layer which is also present at high reynolds number. See description of boundary layer in Frank M white's book
If you are concerned with the laminar-turbulent mix flow then you should consider the transition models like SST gamma theta or K-Kl-Kw model.
SST, K-omega and SA model are by default low-reynolds-number turbulence models. K-epsilon models are added with damping functions to predict the laminar sublayer.
Far is offline   Reply With Quote
Fluent :- turbulence Model prince_pahariaa FLUENT 9 May 20, 2016 04:41
Low Reynolds no turbulence model asurpam Main CFD Forum 0 July 11, 2012 10:04
Reynolds Stress Model in Fluent Vs CFX Tim FLUENT 0 December 6, 2005 23:03
How low for low Reynolds model? Jean-Luc Phoenics 3 March 10, 2001 02:34
a low Re number model for impinging jets mahesh prakash Main CFD Forum 14 September 3, 1999 17:40
