February 28, 2014, 05:55 |
Divergence Problems and Errors
Mark
Rep Power: 13 |
I have modelled a basic impinging jet with the nozzle diameter 0.016m and at a Reynolds Number of 90,000 and a H/d ratio of 10. I have had the following message (which I have attached in terms of a screen shot) from Fluent when I try to run it. My boundary conditions are shown on the other attachment labelled BC's. My solution setup is: Density Based Energy Equation - On Spalart-Allmaras Air as Ideal Gas Operating Conditions = 0 pressure Pressure-far-field - Gauge pressure 101325Pa at 288K Velocity-Inlet - X velocity = 82.166m/s, Pressure = 101325Pa, Turbulent Intensity 0.01%, Hydraulic Diameter = 0.016 at 288K Solution Method is Implicit Can anyone shed some light on why I am getting the error and divergence message. I am teaching myself this program and am struggling with this bit. Also would I need to scale the mesh so that I am getting the appropriate readings even though my geometry is exactly the size that it will be in my experiment? Any help would be hugely appreciated. Many Thanks Mark. |
[BEGINNER] Problems running tutorials (incompressible) in OF 2.xx | Jaro | OpenFOAM Running, Solving & CFD | 8 | March 16, 2016 08:27 |
Unexpected step-to-step divergence? | petr.f. | OpenFOAM Running, Solving & CFD | 4 | September 6, 2013 05:02 |
Efficient multigrid algorithms for problems with dominant high frequency errors | Caluca | Main CFD Forum | 0 | November 29, 2011 06:28 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 06:24 |
Modeling in micron scale using icoFoam | m9819348 | OpenFOAM Running, Solving & CFD | 7 | October 27, 2007 01:36 |
