Valve seat warning problem
Old   February 25, 2014, 10:17
Exclamation Valve seat warning problem
Michael Hilton
soliddesign is on a distinguished road
I have designed a geometry of a piston cylinder with valves.
However, when using the Ansys ICE package, when i select the valve seat in the input manager and click generate i keep getting the same error "select valve seat for the valve". Is anyone aware of this warning and how to solve it as I have been stuck on the solution for quite some time.
I have attached jpeg files showing the error message and the valve seat i chose.
Thank you
soliddesign is offline   Reply With Quote
Old   September 2, 2022, 05:06
rahma
ansi rahma is on a distinguished road
please i need how to solve this is problem about the valve seat
ansi rahma is offline   Reply With Quote
ansys 14.5, icem 3d, piston, valve simulation
CFX-Pre problem, pls help!!! cth_yao CFX 0 February 17, 2012 01:52
Compilation errors in ThirdPartymallochoard feng_w OpenFOAM Installation 1 January 25, 2009 07:59
[OpenFOAM] Paraview command not found hardy ParaView 7 September 18, 2008 05:59
OF14 compilation error bistreamb is already declared in this scope rafal OpenFOAM Installation 5 August 26, 2008 12:23
Add icoLagrangianFoam to FoamX dyxu OpenFOAM Running, Solving & CFD 10 June 11, 2008 10:53
