February 24, 2014, 06:35 |
Plot Monitor Resuls Vs No of Cells
Mark
Rep Power: 12 |
I am tring to do a mesh independance study and I want to plot my monitored values against the number of cells in my 4 different meshes to see how if there are any big jumps in results when increaseing the number of cells. Can anyone suggest how I can do this?
Thanks Mark |
February 24, 2014, 11:05 |
Philipp
Rep Power: 27 |
Use excel...
The skeleton ran out of shampoo in the shower. |
February 24, 2014, 16:04 |
Mark
Rep Power: 12 |
Problem is I can't find the "No of Cells" to select fory access?
February 25, 2014, 03:34 |
Philipp
Rep Power: 27 |
But if you create the 4 meshes, you will see the number of cells. What exactly is the problem?
February 25, 2014, 09:56 |
Juhti
Rep Power: 12 |
Hi Mark,
What i would do in your case is to export data as ASCII to excel: x-coordinate, y-coordinate and the propierty you want to evaluate for each mesh. Then you should dispose each trio of each mesh data with x & y-coordinates in ascendent values (excel) and plot the 4meshes with the same base (x&y coordinates) and the propierties: If you are capable of, I have never tried, you can use a surface 3D-plot in excel or othes SW with the coordinates and the propierty studied. If not you can make a 2D plot, choosing different surfaces of control like y=0; y=0.1 ... And plot the results of the four meshes in the same graphic or four graphics with the same base (as the dimensions won't change) and you can compare them. Is that what you mean? |
February 25, 2014, 10:55 |
#6 | |
Mark
Rep Power: 12 |
I 'm not sure if you link the flow fluid systems to be able compare the four meshes. I hope this makes sense and thank you for all you help so far. Much appreciated. Mark |
February 25, 2014, 11:29 |
#7 | |
Rep Power: 26 |
Or in Fluent, once you have opened the simulation, there is in the menu "Mesh", "Info" and then "Size", which will show you the number of elements. |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
[ICEM] error analysis | despaired student | ANSYS Meshing & Geometry | 7 | June 27, 2012 11:57 |
meshing F1 front wing | Steve | FLUENT | 0 | April 17, 2003 12:37 |
Ignore cells on partition boundary | Karl | FLUENT | 7 | May 11, 2002 22:12 |
UDF: neighbour cells, upwind cells | Dmitriy Makarov | FLUENT | 0 | February 18, 2001 13:53 |
