February 23, 2014, 15:20 |
Heat flux as a function of temperature
Brandon
Transient heat transfer modeling.
There are 3 thermoelectric coolers on the bottom of a chamber. The heat flux is a function of the temperature of the cooler (wall temperature), q=f(T), the larger the temperature is, the smaller the heat flux will be. In other words, it's about how to create a wall heat flux function with respect to its temperature. Can this problem be solved using UDF? If so, can anyone give me some ideas of the UDF? Many thanks! |
February 24, 2014, 03:57 |
Flavio
Rep Power: 16 |
Hi Laplace,
you can use a DEFINE_PROFILE: you call the wall temperature (maybe you need also a DEFINE_ADJUST) and write the function for the heat flux. I suggest reading UDF Guide for info about these DEFINE UDFs. Regards
Bionico |
February 6, 2021, 16:12 |
#3 | |
ahmet kaya
Rep Power: 6 |
fluent - udf |
UDF-Specific heat as a function of Temperature | ahvz | Fluent UDF and Scheme Programming | 14 | February 26, 2016 06:14 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 06:42 |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 10:31 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 07:42 |
Concentric tube heat exchanger (Air-Water) | Young | CFX | 5 | October 7, 2008 00:17 |
