Heat transfer over prediction in coupled b.c. |
February 20, 2014, 11:29 |
Meriam
Hello!
I am simulating a flow field over a flat plate. The flat plat has thickness 5 mm, its bottom surface is heat flux b.c. and upper surface is coupled b.c. since it is shared to both fluid and solid zones. The 3D simulation geometry is a quarter of full domain, therefore I have two symmetry b.c. The problem I found is that when energy model is used after isothermal simulation, the result of surface heat transfer coefficient (or temperature on surface) shows over-prediction in first raw of cells from symmetry b.c. (see link below). The other raws of cells are verified with some experiment data. https://www.dropbox.com/s/1usjrtov6g...escription.jpg Can anyone help me to find the solution? Meriam |
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff | swahono | OpenFOAM Running, Solving & CFD | 10 | October 15, 2018 06:43 |
coupled solver for heat exchanger | chinna | FLUENT | 1 | July 28, 2013 17:13 |
Heat Transfer in Porous Medium | eryan | STAR-CD | 0 | September 28, 2010 14:14 |
Coupled Heat Transfer Simulation | asder | CFX | 4 | March 7, 2008 14:51 |
Prediction of wall heat transfer coeff. | Sridhar | Main CFD Forum | 0 | August 9, 2002 08:27 |
