species transport, mass transfer rate
Old   February 20, 2014, 09:30
Default species transport, mass transfer rate
mattk
mattK is on a distinguished road
hi ,
Im trying to get the mass transfer rate of water vapour from a flat plate.
the setup is the plate is in a box with an inlet at one end and outlet at the other, warm air is coming in and over the plate (at 0.5m/s). The model being used is species transport without reactions.
what I can get is the mass fraction of air and h2o in the system, but cannot find how to get the rate of mass transfer (which I think should be in kg/s)by this I mean the rate at which the water vapur is removed form the flat plate.
is the function available in fluent or would I need a Udf to get it?
mattK is offline   Reply With Quote
Old   February 21, 2014, 05:06
A CFD free user's Avatar
A-A Azarafza
A CFD free user is on a distinguished road
Hi Mattk,
Go to Report/Flux report and from the right column (boundaries), select the appropriate place you want to have mass flow rate. Another option is surface integral from report and from that you can receive several kinds of mass flow report.
Regard yours
A CFD free user is offline   Reply With Quote
Old   February 21, 2014, 13:40
mattk
thank you for that,
I will have another look and see how I get on
kind regards
Old   April 2, 2021, 06:44
Jack0210Jack is on a distinguished road
I have this issue as well. I would like to know the mass transfer rate in the domain not the surface. How should I get it.
Thanks.
Jack0210Jack is offline   Reply With Quote
Old   September 16, 2021, 15:22
Chris
cbooks77 is on a distinguished road
If you are using a built in interphase mass transfer model or custom UDF then just go to the phase interaction under the dropdown for a contour plot. This will show the mass transfer rate in kg/(m3-s)
cbooks77 is offline   Reply With Quote
mass transfer, mass transport
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
mass flow rate... sanjar OpenFOAM Running, Solving & CFD 1 December 2, 2013 01:09
mass transfer in ANSYS thipps ANSYS 1 August 29, 2013 12:05
Species Mass Transfer Abu-Khawlah FLUENT 0 December 9, 2005 11:35
additional variable mass transfer in CFX5.6 john CFX 1 February 14, 2004 01:30
