How to use Eddy Dissipation rate only When using Finite rate/Eddy Dissipation model
Old   February 19, 2014, 00:01
Default How to use Eddy Dissipation rate only When using Finite rate/Eddy Dissipation model
Dziyad Dzulfansyah
Dziyad is on a distinguished road
hello everybody i want simulate biomass gasification process. i have problem about first reaction. i want to create reaction vol --> aCO + bCO2 + cH2 + dC2H2. I want to set in Eddy Dissipation rate only. But in case, i am using Finite rate/Eddy Dissipation model for all reaction. How to use Eddy Dissipation rate only when using finite rate/Eddy dissipation model? Thank you very much
Dziyad is offline   Reply With Quote
Old   February 19, 2014, 09:10
François Grégoire
macfly is on a distinguished road
In this model, the reaction rate is the smallest value between the Arrhenius and the eddy-dissipation reaction rates. Edit the parameters of the Arrhenius rate (e.g., pre-exponential factor = temperature exponent = 1e+30, activation energy = -1e+30) so that it is very high, and therefore never the smallest value.
macfly is offline   Reply With Quote
Old   February 19, 2014, 18:25
Dziyad Dzulfansyah
Thank you very much for the answer, macfly. It works
eddy dissipation model: combustion doesn't occur roukaia FLUENT 2 November 18, 2020 11:23
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
Chemical reaction using Eddy Dissipation Model in FLUENT hyperflow FLUENT 5 June 11, 2012 05:54
finite rate/eddy dissipation model roukaia FLUENT 2 January 3, 2012 13:57
Eddy Dissipation Model Thomas Main CFD Forum 2 November 7, 2002 08:19
