February 18, 2014, 11:33 |
Periodicity in wet clutch simulation
Tarin
Rep Power: 12 |
Dear friends,
I’m trying to simulate a continuously slipping wet clutch to see the thermal evolution in the discs. Due to the thermal symmetry I can simulate only half of the friction disc rotating against half of a reaction plate which is stationary (I mean half in thickness). I have defined the cell zone corresponding to the reaction plate as stationary while the cell zone corresponding to the friction disc is defined activating the Mesh Motion and defining a rotating speed. The lining in the friction disc has radial grooving pattern. That means that when the clutch is closed and the friction disc is slipping against the reaction plate there will be zones where we will have solid-solid sliding while in the groove I will have fluid. Concerning the interfaces I have the following: 1 interface for the reaction plate which I couple with the 2 interfaces of the friction disc (1 for the fluid in the groove and 1 for the rest, which will be solid-solid zones ). Then I generate volumetric heat source in a thin wall in the shadow face corresponding to the solid-solid region. It seems to work OK when simulating the whole system but it is a rotational periodic geometry and I would like to simulate only a sector of the discs. The problem comes when defining the interfaces: This time I select the interface corresponding to the reaction plate and the interfaces corresponding to the friction disc and create the interface after activating “Periodic repeats”. In this moment a warning message appears saying that “there are no periodic zones touching the interface zone with id 13” I think the reason is that there are surfaces (solid-solid or fluid) in the interface that do not touch periodic contours and that’s why I can’t do “Periodic Repeats” And when initializing the solution an error appears: FLUENT received fatal signal (ACCESS_VIOLATION) How can I solve it????? Thank you in advance!!!!! |
November 15, 2018, 10:36 |
Better late than never!!!
The solution to all your problems is to buy a new program called nCode. It is like magic. And its really really cheap. Hope it was useful!!! |
clutch simulation, cooling, heat transfer, periodic condition, periodic motion |
[ICEM] Two kinds of periodicity in one project | PS_KA | ANSYS Meshing & Geometry | 3 | January 22, 2014 05:09 |
[ICEM] Hybrid Meshing and Periodicity | RalfBecker | ANSYS Meshing & Geometry | 0 | October 31, 2013 07:31 |
GUI crash and simulation engine still running | RPJones | FLOW-3D | 2 | November 9, 2010 09:18 |
clutch simulation | novice | Siemens | 0 | September 5, 2005 02:11 |
3-D Contaminant Dispersal Simulation | Apple L S Chan | Main CFD Forum | 1 | December 23, 1998 11:06 |
