Question on setting the boundary condition
Old   February 18, 2014, 04:13
Question Question on setting the boundary condition
jackymak is on a distinguished road
Hi everyone,
I am doing my FYP with studying the kitchen ventilation system. I have few questions when I set the boundary condition.
As the figure show, the blue part is the inlet, red part is the outlet and other is the duct and the body of the ventilator.
The cubic near the outlet is the exhaust fan.
The model is k-epsilon. I set the inlet and outlet are pressure-inlet and pressure-outlet respectively. Is it correct? Also how can I set the turbulence with correct parameter? Furthermore, is there any other things I need to set?
Here is the spec. for the exhaust fan:
Exhaust Fan
Dimension 970W x 780L x 800Hmm
Dia 15inch
Duty 2.2kW
Electrical 380V50Hz 3phase
Pressure
406 - 387Pa
Flow rate 5818 to 12544m3/h
rpm 930rpm
Wt. 148kg
Please help me, thank you
Jacky
jackymak is offline   Reply With Quote
UDF setting wall boundary condition with a DEFINE_PROFILE NLao FLUENT 3 September 2, 2019 01:33
[ICEM] ICEM incorrectly setting boundary condition siw ANSYS Meshing & Geometry 1 July 29, 2013 07:23
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Question about boundary condition setting for a specific case lnk CFX 1 July 26, 2012 16:57
question about OpenFoam-temperatureGradient boundary condition gulru OpenFOAM 2 March 24, 2011 12:50
