dynamic mesh + inflation layers
Old   February 17, 2014, 05:04
Default dynamic mesh + inflation layers
Albino is on a distinguished road
I am trying to model vortex induced vibrations, although with flow that passes over two cylinders. 2D model.
I have not been able to get inflation layers to work with dynamic mesh for the moving cylinder. I can have them for the stationary cylinder without issues, however as soon as I use them for the moving cylinder I get "dynamic mesh failed - negative volume" error after some iterations.
Watching the mesh after this error shows the model (or the mesh) having "gone into itself".
My question is; How do i use inflation layers with a moving object? The cylinder is allowed to move in both X and Y directions (no rotations though).
I have tried smoothing, layering and remeshing - none is working for me. Am I missing something?
Reason I want inflation layers is to have y+ of 1. I use k-omega SST and want to capture seperation properly (Re = around 1.5e6, critical).
Any tips, feedback and comments are welcome.
Thanks!
Albino is offline   Reply With Quote
Old   February 18, 2014, 12:21
stumpy is on a distinguished road
Try version 15.0 (which switched to node based smoothing) and use the "Deform Adjacent Boundary Layer with Zone" option.
stumpy is offline   Reply With Quote
Old   February 19, 2014, 07:47
That sounds like exactly what I need. Too bad my school only offers v14.5 of Fluent.
Thanks for the respons though!
Old   May 15, 2014, 14:59
Default use mapped mesh + layering
Shawn Fotovati
sfotovati is on a distinguished road
Here is what to do. slice your geometry in such a way you can make mapped faces for your mesh generation. set the number of mesh on edges to cover the exact size you wanted the inflation does. now in Fluent set the dynamic mesh with layering, and it will work for you.
good luck
sfotovati is offline   Reply With Quote
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 08:34
Dynamic Mesh on Pintle type injector. herntan FLUENT 16 September 4, 2020 09:27
Dynamic mesh is not getting updated. cardio FLUENT 1 May 20, 2014 09:41
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
