February 16, 2014, 09:54 |
Velocity Inlet/Outlet - Sinusoidal velocity
Jul
Rep Power: 12 |
Hi everybody,
I am working on the active control of boundary layer and trying to modelize a pulse jet localized on the suction side as shown on this picture: I tried to set a sinusoidal velocity to get a blowing/sucking system however as soon as the velocity goes under zero, the calculation diverges and in addition, the velocity resulting is not negative but extremly high (3000 m/s instead of -150 m/s ) So my question is: is it possible to set a negative velocity to modelize suction ? and if yes, how should i do ? Note that I want to modelize blowing and sucking, so I don't want to set a pressure outlet to only get a suction surface. Thank you, Cheers, Julien |
LES and TKE calculations | MST | Main CFD Forum | 3 | May 30, 2016 07:26 |
Having trouble adapting serial UDF to work in parallel | muyuntao | Fluent UDF and Scheme Programming | 1 | November 10, 2015 14:42 |
Radial velocity and tangential velocity on centrifugal fan, | johnnyp | FLUENT | 2 | May 24, 2013 08:10 |
Transient sinusoidal velocity inlet | mrestrepo30 | FLUENT | 2 | September 27, 2010 13:03 |
how to compute relative velocity from absolute? | spk | Main CFD Forum | 3 | July 9, 2010 09:42 |
