February 16, 2014, 06:03 |
High drop in residuals
Harry
Rep Power: 13 |
If drop in residual is high, for example, drop from 1e-01 to 1e-06 in every time step while taking about 20 inner iterations per time step for convergence. Is it OK or i should decrease time step and/or should refine my mesh etc.. |
February 16, 2014, 06:39 |
Meimei Wang
Rep Power: 16 |
That is not high. That just means your simulation is easy to converge. Grids refinement could only be due to large discretization error but nothing else. Grids independence study should be ahead of running simulation to obtain the results.
Best regards, Meimei |
February 16, 2014, 07:51 |
Harry
Rep Power: 13 |
Thanks Meimei. So drop in residual either from 1e-01 to 1e-06 or 1e-03 to 1e-06 is not a big deal. Basically i want to judge quality of mesh from residual behavior. If oscillations in inner iterations for convergence is high (e.g between 20 and 40) will it effect result? if yes then where should we look at?
Thanks again |
[Tutorials] Tutorial of how to plot residuals ! | wolle1982 | OpenFOAM Community Contributions | 172 | December 6, 2024 07:20 |
motorBike Residuals for SST k-omega... and mine | JR22 | OpenFOAM Running, Solving & CFD | 6 | August 1, 2013 10:08 |
Poor Residuals at Intersection Between Symmetry Plane and Airfoil Leading Edge | TWaung | CFX | 2 | February 16, 2010 09:11 |
a problem in calculating pressure drop in Fluent? | yu chun | FLUENT | 1 | May 18, 2004 04:40 |
drop fall velocity | ozgur | FLUENT | 0 | January 29, 2004 12:22 |
