Reading a fluent data file (.dat) using another application
Old   February 14, 2014, 13:42
Default Reading a fluent data file (.dat) using another application
Debanjan
debanjanmukh is on a distinguished road
I am relatively new to using Fluent for CFD, and I have a simple steady solution that I managed to set-up. I saved the Fluent case and data files (.cas and .dat) on my computer. I am now interested in using an external application to open that .dat file so that I can see the data file pattern, and try and write a simple parser for it in Fortran to read the nodal velocity data. I was wondering whether there is any way to ensure that the '.dat' files are readable by other text editing applications or so ?
Thanks.
debanjanmukh is offline   Reply With Quote
Old   February 14, 2014, 13:57
Debanjan
Thanks.
I would like to add on to the question - I figured out how to read the file using an external application. Typical settings for writing the case and data files are to write binary files. While saving the files from Fluent, all you need to do is to uncheck that option.
However, I have now questions on the way these data files are structured. I was wondering whether anyone can help me with a way to extract the nodal velocity data from these files ?
Thanks.
data files, fluent
how to calculate mass flow rate on patches and summation of that during the run? immortality OpenFOAM Post-Processing 104 February 16, 2021 09:46
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 02:22
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 18:51
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
