Oscillating Foil - 2 domains issue
Old   February 13, 2014, 03:44
Default Oscillating Foil - 2 domains issue
adubois is on a distinguished road
I am simulating the flow around an oscillating foil using the combination of two udf (zone_motion and cg_motion). I meshed a structured c-grid around the foil itself (which will move as 1 zone and does not deform within the zone) and created an unstructured grid around this c-grid. The motion of the foil-zone is defined using the zone_motion-udf, while the motion of the "gap" in the unstructured grid in which this zone is located is defined using the cg_motion-udf. The motion match up perfectly so that the domain deforms and oscillates as wanted.
But now this is where the problem shows up, apparently FLUENT lets the flow move over the moving zone (flow is deformed by the motion of the zone which is of course not realistic since it is only a modelling approach). This can be seen in the figure (transient), I added another figure of a steady state calculation on the still grid to show that the interfaces indeed work.
Any suggestions on how to solve this problem?
adubois is offline   Reply With Quote
pimpleDyMFoam issue for pitching foil PLD OpenFOAM Running, Solving & CFD 3 May 23, 2017 14:54
[ANSYS Meshing] Displaying solid domains in CFD Post without meshing them. hda ANSYS Meshing & Geometry 5 October 24, 2016 10:26
Porous domains in contact 0906536m CFX 3 September 30, 2013 19:34
Issue trying to get a icoFoam to solve for an oscillating cylinder: asymmetric solver Murray OpenFOAM Bugs 0 October 25, 2011 18:16
Multiple Solid Domains - Interfaces Scott CFX 8 July 31, 2008 16:20
