How to use the thread_storage macro?
Old   February 10, 2014, 22:53
Default How to use the thread_storage macro?
Michigan
lxlxlxt is an unknown quantity at this point
Hi all,
I'm getting the error as follows:
C:\PROGRA~1\ANSYSI~1\v145\fluent\fluent14.5.0\win6 4\2ddp\fl1450s.exe received fatal signal (ACCESS_VIOLATION)
1. Note exact events leading to error.
2. Save case/data under new name.
3. Exit program and restart to continue.
4. Report error to your distributor.
Error Object: #f
I've got someone answered like
"here are several causes which we will discuss.
For example, in a UDF, you may probe the cell temperature using the macro C_T(c,t). However, if you have not turned the energy equation on, then there is NO temperature stored, and you will get an ACCESS_VIOLATION.
To check a Thread for whether a variable is stored on it, you can use the THREAD_STORAGE(t, SV_XXX) macro, where SV_XXX is the storage variable for the equation of interest. For the energy equation, you would use SV_T. This macro returns a pointer to the data. The value is NULL if the data is not available. See storage.h for a complete list of storage variables.
Another cause for the macro is that your case has a UDF hooked, but you do not have the UDF available. The solution is to make sure you have the UDF directory in the correct location relative to the case file. "
I'm pretty sure that I can exclude the second cause. But how to use the THREAD_STORAGE(t, SV_XXX) macro? Do I need to write a new udf or something? How?
lxlxlxt is offline   Reply With Quote
access violation error, thread_storage
StarCCM+ Command line options and Macro execution isidp STAR-CCM+ 8 January 29, 2013 06:00
Macro Problem!!! eRzBeNgEl STAR-CCM+ 3 August 9, 2011 03:04
Macro Trouble -Winows Explorer Crashes with Macro Martin Castillo FLUENT 1 July 25, 2007 05:18
Macro problem cfddummy Siemens 1 April 9, 2007 13:37
Call a macro from a macro Flav Siemens 2 July 1, 2004 06:42
