Pressure distribution on a surface, numerical data
Old   February 10, 2014, 09:47
Default Pressure distribution on a surface, numerical data
Francisco
Bollonga is on a distinguished road
Hi everybody,
I'm simulating the flow over an inclined flat plate and I would like to get the pressure distribution over the surface in numerical data, to work with it in Matlab.
How can I do it? Do I have to use a UDF to write the pressure data and each point coordinates at the desired timesteps? Is there any fluent tool to do that?
Thank you guys!
Bollonga is offline   Reply With Quote
Old   February 10, 2014, 10:11
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
Under "Calculation activities" in the Fluent GUI you can set up an automatic export.
Here you can choose the format of the exported file, the location of the data to be exported and the variables.
You can also specify a time step interval if you dont need the data from every time step.
Or you could record a macro where you export the data you want to transfer to matlab manually. Find this option in "calculation activities" -> "execute commands" -> "define macro".
Then you can record something like file -> export -> solution data
flotus1 is offline   Reply With Quote
Old   February 10, 2014, 10:19
Francisco
Thanks a lot. I'll try the automatic export option as I'm not very used to macros.
How could I select the surface in which I want to get the pressure using the macro option?
Old   February 10, 2014, 10:26
flotus1's Avatar
Alex
In the automatic export window, you get to select the surfaces for which you want to export the data. You will see what I mean once you opened the window.
Old   February 10, 2014, 10:31
Francisco
I was talking about the macro option, I guess a macro is like some text line commands recorded, right? And I would like to know how to select the surface following this approach, the automatic report approach is clear to me.
Thanks!
Old   February 10, 2014, 10:51
flotus1's Avatar
Alex
I misread, sorry about that.
Giving it a second thought, I dont think that a macro is the best option for your application since it will overwrite the previous results.
Old   February 11, 2014, 04:33
Francisco
Just a question, Alex.
As I posted on this thread http://www.cfd-online.com/Forums/flu...o-surface.html I would like to compute forces on an iso-surface or a clip-surface which are not a named part. Is there a way to compute that force?
Thanks!
Old   February 11, 2014, 05:06
flotus1's Avatar
Alex
I gave this a try, and apparently you can apply an automatic export to isosurfaces aswell.
Not sure how you want to define a force on a surface inside a fluid. Actually that seems to be the tricky part here.
Old   February 11, 2014, 05:10
Francisco
Okay, but it seems I cannot do it in the results/reports/forces option. I can only choose named selections there and it would be really usefull to be able to check forces on some unnamed areas.
Old   February 11, 2014, 05:15
flotus1's Avatar
Alex
I am quite sure that the force on any surface element inside a fluid has to be zero because pressure and shear stress on both sides of the surface have to be equal.
Old   February 11, 2014, 05:19
Francisco
I mean forces on a wall surface that is part of a body. These shouldn't be zero.
Old   February 11, 2014, 05:23
flotus1's Avatar
Alex
These are the forces on one side of the surface.
And if they are part of a boundary, you should be able to do any postprocessing you like within fluent.
Maybe we need a more concrete example on what you are trying to do.
Old   February 11, 2014, 05:28
Francisco
I have an inclined flat plate near the ground in an atmospheric flow. I'm computing Cd and Cl for the whole plate, but I would like to check the force or coefficient on just a corner or a specific area of the panel.
I guess this should be done in a post-process stage but I don't know how.
Old   February 11, 2014, 05:41
flotus1's Avatar
Alex
I dont know how to get these forces from the force reports in fluent directly.
But what you can do is calculate the surface integral of shear stresses and pressure. This can be applied to clipped surfaces or isosurfaces.
fluent, numerical data, pressure distribution
Pressure Outlet Guage pressure Mohsin FLUENT 36 April 29, 2016 18:16
how to create surface pressure data file josip76 FLUENT 0 June 26, 2011 02:10
plot pressure distribution on a section of 3D wing ROOZBEH FLUENT 3 April 21, 2008 04:30
Does star cd takes reference pressure? monica Siemens 1 April 19, 2007 12:26
Where can find airfoil data with pressure distribution or aerodynamic data Ahlo Main CFD Forum 5 January 12, 1999 23:45
