FLUENT Erosion DPM (Methane with Sand) - Strange Erosion Contours
Old   February 7, 2014, 13:19
Default FLUENT Erosion DPM (Methane with Sand) - Strange Erosion Contours
Jasmine
chongjqw is on a distinguished road
Hello all,
I intend to model sand laden flow in a pipe of a certain complex geometry, and have more less followed the tutorial here (www.cfluid.com/batch.download.php?aid=642) except with a different erosion correlation (Det Norske Veritas's) and with a different flow condition of methane gas instead of water. The computed velocity flow field seemed fine.
Below are the velocity contours and the erosion contours I computed, of which the erosion contours are obviously wrong (negative erosion? ). However, I am unable to find the problem with my simulation and hope that someone here can enlighten me.
Velocity Contours
Erosion Contours
Many thanks in advance.
chongjqw is offline   Reply With Quote
Old   February 21, 2015, 05:17
YANNAPOL SRIPHUTKIAT
YANNAPOL is on a distinguished road
Dear Chongjqw,
Could you please send me the tutorial I cannot access the link ?
YANNAPOL is offline   Reply With Quote
Old   February 21, 2015, 05:57
ghost82's Avatar
Rick
ghost82 will become famous soon enough
Can you show us the correlation you used and specify which parameters did you input in the wall boundary conditions for walls?Probably the problem is there (equation or units).
Daniele
Google is your friend and the same for the search button!
ghost82 is offline   Reply With Quote
Old   February 22, 2015, 22:17
Dear Daniele,
If I have 2 phases
-Primary Phase - water
-Secondary Phase - CaCO3
Can Accretion Model simulate the particle or granular of CaCO3 deposit to the wall which the excessive CaCO3 enough to block primary phase and cause clogging ?
You can see my attachment for explanation.
Best Regards,
Yannapol S.
FLUENT Erosion DPM - Strange Erosion Contours chongjqw FLUENT 0 February 7, 2014 03:43
DPM Erosion Model Question CFDD FLUENT 0 August 21, 2013 20:06
URGENT! PROB. WITH FLUENT 6.4 in DPM in PARALLEL Aris Nikolopoulos FLUENT 4 January 13, 2008 18:36
URGENT QUESTION ABOUT DPM EROSION!!!!!! alex FLUENT 2 October 28, 2005 07:33
DPM model in FLUENT Jürgen Schmidt FLUENT 0 October 27, 2005 15:39
