Temperature and heat flux wall boundary condition
Old   February 1, 2014, 05:51
Default Temperature and heat flux wall boundary condition
Hamid
L. Hamid is on a distinguished road
Dear All,
In my model, I have a coil which transfers the heat flux 5000 w/m2 to gasoline. I set the wall of coil boundary condition by this heat flux. After convergence the model, I checked the surface temperature of the coil. It was 1000 K. But In real, the surface temperature of the coils shouldn't exceed 400 K. How can I control the temperature and heat flux of the coil?
Any help would be appreciated
Hamid
L. Hamid is offline   Reply With Quote
Old   February 3, 2014, 08:49
pakk will become famous soon enough
I think you are asking the wrong question.
The real question is why your simulation gives different results than the "real" world. Check your material coefficients, for example.
If your simulation does not give the result that you expect, you should not just change settings until you get wat you expected... You should check if your expectations were right, and find out what is the reason that it is different!
pakk is offline   Reply With Quote
Old   February 10, 2014, 00:59
Hamid
dear Pakk
Tank you for your reply. I'll check.
Radiation interface hinca CFX 15 January 26, 2014 18:11
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
