error when writing data
Old   January 29, 2014, 18:09
Default error when writing data
François Grégoire
macfly is on a distinguished road
Fluent crashes when it tries to write data and I don't know why.
- Windows 8.1
- Ansys 14.5.7
- 3D model with turbulence, combustion, etc.
- Fluent launched in parallel mode and mesh automatically partitioned
Here is the message in the GUI:
Writing "| gzip -2cfv > D:\init.dat.gz"...
999999 (..\src\mpsystem.c@1172): mpt_read: failed: errno = 10054
999999: mpt_read: error: read failed trying to read 32 bytes: No such file or directory
MPI Application rank 0 exited before MPI_Finalize() with status -1073741819
The fl process could not be started.
Error: Error writing "| gzip -2cfv > D:\init.dat.gz".
Error Object: #f
Message from Cortex process==> Connection with host is broken. It may have crashed.
Any idea please??? Thx
macfly is offline   Reply With Quote
Old   January 29, 2014, 20:59
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
it says no such file or directory ? is the d: and external hard drive ? may be it's unplugged ?
Have you tried another location ?
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   January 29, 2014, 23:26
François Grégoire
No, I run a dummy test case with the same commands, same udf, and everything works fine.
It just doesn't work with my big model, although my model is not that big with 250000 cells and 10-12 variables.
It's very annoying and I read all kinds of half-answers going in every directions online... Confused and don't know what to do except lighten my model step-by-step and going by elimination.
Old   January 29, 2014, 23:31
François Grégoire
same problem in that thread, what the hell am I supposed to do with answer #2...?: http://www.cfd-online.com/Forums/flu...tml#post149284
Old   January 30, 2014, 12:24
diamondx's Avatar
Ghazlani M. Ali
he is refering to the type of MPI, when you launch FLUENT you get the right to choose in the parallel setting from diferrent king of mpi: pcmpi, intel...
Regards,
Ali
Old   January 30, 2014, 12:32
François Grégoire
I always use pcmpi on Colosse, and you? If I use another mpi there is a message that recommends using pcmpi instead, somewhere in the output files..
From reading around, I think it has to do with the mesh partitioning. I added a line in my .jou telling Fluent to partition with another method than the default Metis. I'll see if it works.
I also read that it may be good to modify/save the case in serial, then launch it in parallel, for some obscure reasons...
Old   January 30, 2014, 12:39
diamondx's Avatar
Ghazlani M. Ali
[QUOTEI always use pcmpi on Colosse, and you?][/QUOTE]
me too.
Did you get this error message on colosse or you desktop ?
Regards,
Ali
Old   January 30, 2014, 12:43
François Grégoire
both, local and Colosse
Old   February 3, 2014, 16:23
François Grégoire
In the end, it looks like the default 'Metis' mesh partitioning method was causing some data communication problems. I changed the partitioning method to 'Cartesian Axes' and the write-data doesn't cause me headaches anymore.
Couples of hours lost on that!
Importing surface/profile for data writing in Fluent fadiga FLUENT 4 July 12, 2014 02:23
Writing data after every timestep Sri FLUENT 3 March 8, 2007 13:33
Writing out specific data from FLUENT kui FLUENT 1 November 7, 2006 21:33
Writing out specific data from FLUENT Pavan FLUENT 5 October 19, 2006 12:26
Writing mass fraction data file Sankalp CFX 1 September 17, 2004 11:54
