Air Flow Analysis around a Wind Turbine
Old   January 29, 2014, 15:59
Lightbulb Air Flow Analysis around a Wind Turbine
NightHawkRaven is on a distinguished road
I am from an Electrical Engineering background and am working on a wind turbine design project. I am looking to purchase a wind turbine for one of my commercial needs. But before I make a decision on the different types of wind turbines available in the market, I would like to simulate the airflow around a wind turbine and see how the output power and efficiency vary based on the different wind speeds.
I've been trying to gather some information from the different forums on this site, but I would be really happy if somebody could walk me through the basic procedure required to start off at this juncture. I mean, to be specific, how do I start off with the ANSYS Fluent software to simulate the airflow ? Since, I am not designing the wind turbine by myself but instead looking to purchase one, I don't have the CAD model of the turbine either. I've been listening to a lot of techniques such as "Moving Reference Frames", "Sliding Meshes", "Studying the Wind Turbine Wake by replacing the turbine array with Pressure Jump or Porous Media" etc., but I have no clue as to what each of these would mean ! I'm radically looking at the first basic step of the ANSYS Fluent simulation of a wind turbine - so please help me out on this issue.
P.S: Please make sure your response scales down to the most rudimentary level !
NightHawkRaven is offline   Reply With Quote
Old   January 29, 2014, 16:39
Travis Carrigan
tcarrigan is on a distinguished road
I wrote a journal article that describes a few of the things you mentioned. I also used FLUENT for the analysis. It's a VAWT, but the procedure is similar for a HAWT.
http://www.hindawi.com/isrn/renewabl...y/2012/528418/
tcarrigan is offline   Reply With Quote
Old   February 7, 2014, 16:21
Question
Hey Travis,
Thanks for your publication ! But to be honest, I couldn't understand even a bit of whatever was in there ! As I said, I'm practically looking at the first basic step of ANSYS simulation., so please direct me to an even more basic tutorial.
I really appreciate your help in this regard !
Old   February 10, 2014, 18:15
stumpy is on a distinguished road
You should start with some of the basic tutorials in the Fluent documentation, particularly those that deal with rotating reference frames. However, to be honest you could be wasting your time. Getting an accurate answer would take a lot of time and computational resources and reasonable amount of experience. You would need to make sure your mesh was sufficiently refined and resolves the boundary layer well and probably the wakes too. You might need to think about boundary layer transition effects. Would you include ground and tower effects, or just model a single blade, etc. You'd need a cluster and a bunch of parallel licenses to get any reasonable results. I would just look for something that is well proven and from a company that can stand behind its product. Just my 2 cents...
stumpy is offline   Reply With Quote
Old   August 12, 2014, 18:18
Matt
fluid23 is on a distinguished road
NightHawkRaven,
This is probably too little too late, since you posted this 5 months ago. However, I would caution you against using CFD to help you select a wind turbine to purchase. Why, you ask?
1. You will need a massive amount of computational resources to accurately capture the aerodynamics of this problem.
2. If you are a beginner to CFD this problem is likely too complex to start with. People write entire PhD dissertations on only a small subset of the problem you are trying to solve. Your models will complex and large, the potential for human error in the setup is too great.
3. Every wind turbine manufactuer in the entire world provides power curves (Power Coefficient vs Tip Speed Ratio) for their products. This is how people decide to buy them vs another macine. This will give you the information you say you need.
4. If you are hell-bent on calculating these values for yourself, look into the free NREL Design Codes. The easiest is TurbSim, but I think that has been discontinued and replaced with AeroDyn. These are Blade Element Momentum (BEM) codes and are used to design blades and predict their performance and any number of off-design conditions including skewed wake, over speed, and so on. AeroDyn is a little complicated, but has options for modeling dynamic effects as well. Be advised, if you have little to no background in either 2D or 3D aerodynamics, you are going to struggle setting up your model. There are several good books on wind energy which give detailed formulations of BEM theory. I suggest you consult one before you attempt any BEM modeling. (For that matter, I suggest you read a basic CFD text book too before trying to jump into the deep end of the analysis pool).
5. The biggest problem I see with your approach to turbine selection is that you need to have the blade geometry in order to do either CFD or BEM analysis. In my experience, manufacturers rarely provide this data as it is highly proprietary. However, if you have airfoil distrbutions, airfoil aerodyanmic data, and chord/twist distributions you might be able to pull it off...
Good Luck! I am curious to know how your attempt in Feb turned out and if you do end up trying BEM analysis, I will be happy to answer any questions you have.
fluid23 is offline   Reply With Quote
air flow, air flow simulation, fluent, wind tunnel
fluent analysis of wind turbine er_ijaz FLUENT 0 May 1, 2013 05:55
Unsteady flow over a savonius wind turbine Robyfood Siemens 9 March 14, 2012 10:41
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 08:59
radial turbine flow analysis ME Siemens 1 August 16, 2007 04:06
