Lift Coefficient vs Angle of Attach for Pitching Airfoil
Old   January 29, 2014, 04:16
Default Lift Coefficient vs Angle of Attach for Pitching Airfoil
Musa
fkanyako is on a distinguished road
Hi Everyone,
I am performing airfoil Pitching in fluent using UDF. I am using this equation
alpha = alpha(o)+alpha(a)*sin(Wt)
alpha(o) = mean angle of attack (10)
alpha(a) = pitching amplitude (15)
My problem however is how to plot the lift coefficient vs AOA as shown in the picture below. Normally in the static case, you specify the angle of attack for x and y in fluent and report the forces after simulation for each angle of attack. Which means you have to run a lot of cases if your aoa is between (-5 to 25).
However looking at the pitching case and the picture I do not know to plot it. Please any help will be appreciated.
Regards
Franklyn
fkanyako is offline   Reply With Quote
Old   July 9, 2014, 05:26
Pras
prasantasarkar is on a distinguished road
Could you help me with the solution to the problem you mentioned. How to determine the Cl vs AOA for pitching airfoil?
prasantasarkar is offline   Reply With Quote
Old   July 9, 2014, 12:00
Ehsan Asgari
syavash is on a distinguished road
Originally Posted by fkanyako View Post
Hi Everyone,
Regards
Franklyn
Writing a UDF is one tool which can help you plot Cl vs. AOA.
But have in mind that solution of a dynamic pitching airfoil is different from the static airfoil.
Goodluck
syavash is offline   Reply With Quote
Old   July 16, 2014, 08:35
Pras
Does anybody have any example of an airfoil pitching UDF with the AOA part on it, which will give me the AOA at every time step?
Regards,
Pras
airfoil lift and drag coefficient amir_14 FLUENT 5 January 1, 2013 09:30
Determining Stall Angle of 2D Airfoil Active.Aero.Fiero FLUENT 3 October 27, 2010 10:07
Lift Coefficient of an Airfoil. pandelis chatzis Siemens 2 September 5, 2002 04:00
Lift Coefficient Vs. Angle of Attack cfd_pro Main CFD Forum 1 August 23, 2002 18:21
Highest lift coefficient Mark Render Main CFD Forum 5 March 2, 2000 09:30
