January 28, 2014, 23:58 |
Getting error while trying for result
Rep Power: 12 |
Dear Mates,
Please check the attachment. Kindly let me know where I am going wrong. I am using Ansys Fluent 14.5. The model is ready but I am unable to go ahead for analysis. Kindly help. |
January 29, 2014, 03:40 |
log file??
Paritosh Vasava
Rep Power: 23 |
Can you post the log file that fluent created??
January 29, 2014, 03:49 |
log file
Rep Power: 12 |
Thank you so much for your response.
Please find the attachment. |
January 29, 2014, 05:47 |
Rep Power: 27 |
I see that you loaded the cas-file, and loaded the dat-file.
Did you do anything after loading the dat-file? (The log-file shows that some threads are changed, but I can't see if that is done automatically by Fluent, or if you started that.) |
January 29, 2014, 05:59 |
I am not much aware of this
Rep Power: 12 |
Yes that is what I have done. Can you kindly tel me the steps to get the result? What all files are required?
January 29, 2014, 06:16 |
Rep Power: 27 |
I will ask again, because I don't think you read the question: Did you do anything after loading the dat-file? If so: what did you do?
January 29, 2014, 06:20 |
Rep Power: 12 |
January 29, 2014, 06:30 |
Rep Power: 27 |
Then it looks like the dat-file does not completely correspond to the cas-file. They are both the same geometry (because the number of elements agree), but the ID's are different.
How sure are you that this combination of cas and dat files is correct? Where they made at the same time? (check the 'Date modified' in explorer) I have the feeling that you are trying to load an older version of the dat file into a newer version of the cas file, or the other way around. Does this make sense to you, knowing how you generated the cas and dat files? |
January 30, 2014, 00:37 |
Thank you
#9 | |
Rep Power: 12 |
Thank you so much. It was resolved.
