Flow over square Cylinder
Old   January 26, 2014, 15:05
Default Flow over square Cylinder
alireza
alireza_b is an unknown quantity at this point
Hi
I'm trying to solve flow over a square cylinder at Re=5,20. I used velocity inlet and outlet boundary condition. I solved the problem, But my result was wrong, i don't know why?!?????
I attached velocity and pressure contour. As you can see results is wrong.
This problem is very simple, Re=5, laminar flow and ... . But unfortunately my result is wrong.
can you help me?
alireza_b is offline   Reply With Quote
Old   January 26, 2014, 15:10
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
How did you make sure that this is a converged solution?
And could you post an image of the mesh you used?
flotus1 is offline   Reply With Quote
Old   January 26, 2014, 15:24
alireza
I attached image of mesh and convergence history.
Old   January 26, 2014, 16:13
flotus1's Avatar
Alex
Did you try running more iterations? I would run such a simple case until round-off accuracy is achieved. One thing less to worry about.
Judging from the image of the mesh, I recommend using double precision.
Did you use velocity inlet, pressure outlet and symmetry boundary conditions?
Old   January 27, 2014, 04:54
like.no.other
like.no.other is on a distinguished road
Originally Posted by alireza_b View Post
Hi
can you help me?
Hi alireza
which parameter is wrong?
Cd?
Cp?
Please send me your case fine, I can help u
www.CFDiran.ir
like.no.other is offline   Reply With Quote
Old   January 31, 2014, 03:12
alireza
Yes, I did.
I used velocity inlet and pressure outlet. left, top and bottom are velocity inlet and right is pressure outlet. I also used symmetry, but the answer is wrong.
Old   January 31, 2014, 03:17
alireza
Originally Posted by like.no.other View Post
Hi alireza
Cd?
Cp?
Hi
both flow field and Cd are wrong. I check reference value, this is correct but answer is wrong.
Old   February 1, 2014, 14:32
flotus1's Avatar
Alex
Yes, I did.
Please run the case in double precision untill the residuals level out and show the results (residuals+contour plots).
If still not satisfied with the results, use a mesh that is more suitable for low Reynolds number flows. Its the high aspect ratio cells that cause slow convergence. You dont need such a high resolution near the wall.
One more thing: dont expect to get a value for the drag coefficient that matches any reference solution for a square cylinder in free stream.
The extent of the computational domain is not enough for low reynolds number flows.
Top and botom should be symmetry boundary conditions.
Old   February 5, 2014, 05:16
atulurade is on a distinguished road
i think your fine mesh area has not properly defined because it will concentrate result in fine mesh area .
also one more point is that whenever their is flow over bodies then it will shows laminar region somewhat distance along the length not to the the its near by wall region..
atulurade is offline   Reply With Quote
Turbulent Flow in Straight Square Duct - k-ep Validation mcclud STAR-CCM+ 2 August 7, 2012 17:56
flow resistance of cylinder in parallel flow Ralf Schmidt Main CFD Forum 3 May 11, 2009 03:26
grids for flow over a square cylinder student Main CFD Forum 4 April 21, 2009 07:50
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 13:19
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
