January 24, 2014, 05:54 |
Reversed flow at outlet in micro channel
Anvesh
Rep Power: 12 |
I am trying to simulate multi phase flow in a micro channel (unsteady volume of fluid model) with outlet BC as "pressure outlet" set at atm pr. But its showing reverse flow? Why the flow is reversed and what to do to avoid that problem? Help me
reversed flow |
reversed flow in xxxx faces on pressure outlet | franzdrs | FLUENT | 8 | January 4, 2020 21:12 |
Net mass flow inlet vs outlet | Nigui28 | FLUENT | 1 | August 12, 2011 11:09 |
Reversed flow at the outlet | swati_mohanty | FLUENT | 0 | January 5, 2011 02:00 |
pressure outlet (open channel flow) | Willem Brantegem | FLUENT | 2 | April 4, 2007 03:40 |
compressible channel flow.. | R.D.Prabhu | Main CFD Forum | 0 | July 17, 1998 18:23 |
