Conjugate heat transfer in ANSYS-FLUENT
Old   January 24, 2014, 01:31
Post Conjugate heat transfer in ANSYS-FLUENT
Ashutosh
dreamz is on a distinguished road
I am trying to solve a tutorial of conjugate heat transfer from a chip on a printed circuit board being cooled by air flowing over it. The tutorial involves all steps in FLUENT. But I am stuck up in geometric modeling. I am using ansys design modeler of workbench 13.0.
For conjugate heat transfer we need to have shadow walls. According to tutorial three shadow walls must be created. However, I could get only two.
Has anyone solved this problem? Please help me in modeling the problem.
Following is the link of the tutorial--
https://encrypted.google.com/url?sa=...59930103,d.bGQ
dreamz is offline   Reply With Quote
Old   January 26, 2014, 15:07
Dinesh Balaji
DineshramBalaji is on a distinguished road
Hi Ashutosh,
I am also workin on similar case. I tried searchin for the tutorial file. Can you tell me where did you find the file.
DineshramBalaji is offline   Reply With Quote
Old   January 26, 2014, 22:35
Ashutosh
I just found the file via google search. I have put the link for the file in my message.. Try it. Tell me if the link is not working...
Old   January 26, 2014, 22:46
Dinesh Balaji
Its my bad. What I meant to ask was, where did you get the modeling case file for this chip 3d ?
Old   January 26, 2014, 23:05
Ashutosh
Try this link....
http://aerojet.engr.ucdavis.edu/fluenthelp/tutfiles/
Downloand the file by the name postprocess
You will get the .cas file in it... Try it out and let me know if you can get the 3 shadow zones... I hope other users reply too...
conjugate heat transfer, shadow walll, workbench 13
Conjugate Heat Transfer: Wall Heat Flux at Coupled Walls? MaxHeat FLUENT 4 September 14, 2017 11:44
[DesignModeler] conjugate heat transfer in a heat exchanger bhaskorb3 ANSYS Meshing & Geometry 0 December 31, 2012 09:12
Transient FSI heat transfer using FLUENT and ANSYS kevpw FLUENT 0 March 26, 2010 17:04
Conjugate heat transfer problem with porous media piko Siemens 1 April 17, 2009 16:41
Conjugate Heat Transfer analysis using FLUENT Ravi Kiran FLUENT 0 February 16, 2006 05:39
