January 21, 2014, 16:43 |
gambit meshing question
Rep Power: 13 |
I am trying to simulate the two phase flow at a turbine nozzle(water-air) and I have done the geometry(in the bmp file below). I have some problems with the meshing of it because of the irregular shape of the nozzle.I want a more dense mesh across the two walls,to capture the boundary layer and I cannot figure out how to do it. I would like a structured mesh,so it is easy to configure it later (make it coarser and finer, and also move a bit the nozzle to the right,to simulate a different operation point of the machine). The 'face' at the left is for the water and the right one for the air. Should I make 2 virtual faces to enable the implementation of the 2 phase mixture? Thanks in advance geometry.jpg |
[GAMBIT] 3D boundary layer and meshing problem in GAMBIT 2.4.6 | prashanthreddyh | ANSYS Meshing & Geometry | 1 | December 20, 2011 01:35 |
Gambit meshing error | jx | FLUENT | 11 | May 26, 2009 11:35 |
meshing difficulties in gambit | jyothish | FLUENT | 6 | June 7, 2004 05:13 |
Gambit - meshing question | Pei-Ying Hsieh | FLUENT | 1 | November 26, 2001 11:08 |
GAMBIT meshing problem | Gauthier Lambert | Main CFD Forum | 1 | August 3, 2000 10:22 |
