Modeling Radiation and Natural Convection
Old   January 20, 2014, 11:56
Default Modeling Radiation and Natural Convection
itsme_kit is on a distinguished road
Hi
I just gone through one of the ansys tutorials named in 'Modeling Radiation and Natural Convection'
I wonder what gonna happen if we exclude the radiation model
Obviously there will be no radiative heat transfer, so in this case what's the main method in heat transfer? convection or conduction?
itsme_kit is offline   Reply With Quote
Old   January 20, 2014, 14:20
P.Charoen-amornkitt's Avatar
Patcharawat
P.Charoen-amornkitt is on a distinguished road
From my understanding, real basic mechanisms of heat transfer are radiation and conduction. Convection is just conduction that includes the motion of fluids. So, you have to ask yourself that does the fluids in your model moves? And the best thing that could describe 'which mechanism is dominated' between convection and conduction is Nusselt number. hD/k .. I think most cases convection is dominated
Best Regards,
Patcharawat
P.Charoen-amornkitt is offline   Reply With Quote
Old   January 20, 2014, 14:31
Best Regards,
Patcharawat
Hi Patcharawat
Good to hear from you
Actually for this case, initially the air is stationary and no external force exerted on air. And then, because of the temperature gradient, buoyant-driven flow turns up. Maybe at the beginning, only conduction takes place to produce the temperature gradient, as time elapses, both convection and conduction exist. Is my understanding correct
Thanks in advance
Old   January 20, 2014, 14:51
Patcharawat
At first, the air on the hot surface is gained heat by conduction. After that bouyancy force occurs since density of hot air is less than cold air. Then the natural convection mechanism will take place since convection is from conduction + advection, which means convection has included conduction already. So, I think that it's only convection that remains.
Best Regards,
Patcharawat
Old   January 20, 2014, 15:39
Best Regards,
Patcharawat
Let's simplify the phenomenon further, in case that constant density is assumed, as a result, no buoyant force, no air movement. However, we still can get temperature gradient, so in this case, is it only conduction existed
Thanks
Old   January 21, 2014, 06:33
Patcharawat
Yes, if no buoyancy force, no external force, no radiation, only the conduction heat transfer exists.
Modeling Radiation and Natural Convection itsme_kit ANSYS 0 January 20, 2014 11:55
natural convection problem with radiation jorien CFX 0 October 14, 2011 10:26
radiation and natural convection - gravity carlos FLUENT 0 November 19, 2007 05:56
Modeling radiation and natural convection tutorial Amanda Fry FLUENT 1 January 20, 2004 13:50
HELP!!! RADIATION MODELS IN NATURAL CONVECTION dory FLUENT 0 November 29, 2000 11:51
