Node 0: Process xxxx: Received signal SIGSEGV |
March 14, 2024, 02:40 |
It worked for me when I turn off continuous flow interaction
#41 |
karthikvatvat
Rep Power: 12 |
It worked for me when I turn off continuous flow interaction in DPM panel
March 14, 2024, 02:42 |
#42 |
karthikvatvat
Rep Power: 12 |
March 18, 2024, 02:23 |
Solved this error for my case
#43 |
ankit
I was using C_T_RG in my UDF and was getting a similar error & fluent was exiting. Referred to UDF manual and entered
solve/set/expert in fluent panel and turned on Keep temporary solver memory from being freed? Yes This was perhaps happening because these gradient values were not being stored for access by UDF. Worked for me and fluent didn't got killed. But, after initialization, fluent exited again with same error. Any help on this???? Last edited by ankit_tiwari; March 18, 2024 at 04:11. Reason: Faced issues. |
fluent, r15.0, upgrade |
Free Surface Ship Flow | timfranke | OpenFOAM Running, Solving & CFD | 322 | March 3, 2021 10:04 |
mpirun, best parameters | pablodecastillo | Hardware | 18 | November 10, 2016 13:36 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 23:56 |
FLUENT received fatal signal (ACCESS_VIOLATION) | osamaghani | FLUENT | 2 | March 31, 2012 17:15 |
999999 (../../src/mpsystem.c@1123):mpt_read: failed:errno = 11 | UDS_rambler | FLUENT | 2 | November 22, 2011 10:46 |
