Luke Roberts
Rep Power: 0 ![]() |
Hi all,
I am trying to model a body moving constantly in a circle. I tried using a rotating reference frame on the fluid at a speed which equated to 25m/s at my desired radius coupled with a velocity inlet with set angular velocity as shown in the image. I've looked at the reference frame tutorials but can't seem to get it right; the problems I am having are (i have tried lots of different boundary conditions): 1. Outlet not having correct angular velocity - usually causes stagnation or voids which affect upstream flow 2. Total pressure changes with radius while static remains constant - shouldn't this be the other way around I don't know if I am trying to do this the wrong way or missing something fundamental so any help would be greatly appreciated. Thanks |
circular domain, external aerdynamics, rotating region |
Help needed in modelling/meshing a body moving in a pipe which is driven by a fluid | hareshram.n | ANSYS | 1 | July 4, 2024 02:13 |
Moving fluid vs moving body | lovecraft22 | Main CFD Forum | 8 | May 26, 2020 17:42 |
Sliding Mesh - moving body | rw511 | FLUENT | 3 | May 9, 2013 02:37 |
Free surface and moving body | Steve | FLUENT | 0 | August 18, 2004 02:54 |
HELP: unsteady solving of Moving body in fluid | Quain Tchew | Main CFD Forum | 1 | May 21, 2003 23:21 |
