January 17, 2014, 20:51 |
Reversed flow in pressure inlet
le hoang anh
Rep Power: 14 |
Dear fluent user,
I am modeling 3D flow in Nozzle with boundary condition at inlet and outlet is pressure. But after 5000 iteration, I got the warning: reversed flow in pressure inlet, and the number of faces which got that problem is increase. Any one know how to fix this problem and it will cause the incorrect result? Also I set total pressure 164560 Pa, when I got this messenger, I check pressure inlet, it show static pressure equal total pressure. |
January 18, 2014, 19:36 |
Rep Power: 12 |
This is quite common in the first few iterations but after 5000 iterations ...
Do you have to use a pressure inlet BC? Try to use velocity inlet instead if you can. For a nozzle problem I think you surely can. If you cannot, that means your under relaxation factors need to be reduced. There are other solutions too but as I do not know about your specific goal I cannot comment more about it neither. |
January 19, 2014, 04:58 |
le hoang anh
Rep Power: 14 |
Thank you, LDA
Yes, I am using pressure inlet BC. I am modeling two phase flow, so the density is not constant. Therefore, using velocity inlet will give unphysical result. Also, URF I set small 0.1 for all value except pressure 0.5, density 0.5, body weight 1 |
January 19, 2014, 05:17 |
le hoang anh
Rep Power: 14 |
Also, this is the result I checked (still calculate). The result seem very strange, and also different from out experiment.
The method I use: PISO transcent, second order for pressure, least square cell base for gradient, QUICK for all other. Can anyone suggest the solve for this result? |
January 19, 2014, 13:17 |
Rep Power: 12 |
Are you sure you adequately satisfy a LES simulation's requirements in terms of mesh resolution principally?
January 19, 2014, 19:35 |
le hoang anh
Rep Power: 14 |
I think it OK. The mesh for LES, yplus less than 1.
Also I have same result with K-e and K-o |
Unsteady pressure differential between inlet and outlet of the pipe for single phase | joshi20h | FLUENT | 0 | September 26, 2012 13:41 |
Pulsatile pressure inlet with pressure outlet | a.lynchy | FLUENT | 3 | March 23, 2012 14:45 |
Do Pressure Inlet Flow Direction Components Need to Be Normalized? | ScottN | FLUENT | 0 | September 21, 2010 10:18 |
reversed flow at velocity inlet / mass flow inlet | ib | FLUENT | 1 | March 26, 2007 14:11 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 16:00 |
