viscosity defined by pressure and temperature
Old   January 17, 2014, 08:33
Default viscosity defined by pressure and temperature
bleseb is on a distinguished road
Hi @all,
i want to define the viscosity as a function of pressure and temperature.
I need that to calculate an ol, that is mixed with CO2.
I just have a table, where i can go from pressure and temperature to the mix ratio and then from mix ratio and temperature to the viscosity.
Is it possible to give fluent that Table?
Do I need to programm that with UFD?
And: Maybe someone did that before and send me the UFD?
Thanks a lot!
bleseb
bleseb is offline   Reply With Quote
Old   January 17, 2014, 10:31
pakk will become famous soon enough
Hi Bleseb.
Yes, it is possible to use such a table in Fluent.
Yes, you have to use a UDF for that.
No, I don't have such a UDF ready, and I doubt if somebody will have exactly what you want.
Make some efforts in writing such a UDF, and if you come into specific problems, you can ask here.
Good luck!
pakk
pakk is offline   Reply With Quote
pressure, temperature, viscosity
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Too low temperature at combustor outlet romekr FLUENT 2 February 6, 2012 11:02
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
