Partially Premixed Combustion not burning
Old   January 15, 2014, 02:52
Default Partially Premixed Combustion not burning
raymond350 is on a distinguished road
I would like to know the significance of partially premixed combustion simulation where no burning occurs? Does it signify the conditions are not favourable for combustion experimentally as well? Or is it some settings problem?
I had a mesh where burning occurs, but when I refined the mesh, no burning takes place. All settings are exactly the same.
Thanks.
raymond350 is offline   Reply With Quote
Old   January 15, 2014, 07:03
Bharath kumar
bharath is on a distinguished road
Try to interpolate your coarse mesh results with refined mesh and check it once.
bharath is offline   Reply With Quote
Old   January 15, 2014, 07:24
Can elaborate what do you mean by "interpolate coarse mesh results"?
Basically there is burning for the coarse mesh, and no burning for the fine mesh.
Old   January 15, 2014, 12:36
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
Use the results you got with the coarse as an initial data for the refine mesh, and continue calculation on refined mesh, see what's going to happen.
You can do that using the file -» interpolate data
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   January 16, 2014, 05:37
The solution diverged after a few steps when I interpolate the coarse mesh data to the fine mesh.
Old   January 21, 2014, 20:28
What is the significance if there is no burning?
Do people use partially-premixed combustion to determine if combustion is feasible?
Partially premixed combustion problem shashankvu FLUENT 2 April 21, 2015 18:45
Partially Premixed Combustion - Direct Fired Boiler oknus FLUENT 0 April 10, 2012 11:52
Partially Premixed Combustion: Single inlet-no Outlet amita FLUENT 0 May 8, 2009 06:52
Partially Premixed Combustion rbw OpenFOAM Running, Solving & CFD 9 July 28, 2006 07:54
Mixture fraction in Partially premixed combustion Viktor FLUENT 1 December 30, 2005 00:30
