January 14, 2014, 06:51 |
Cd and Cl calculation by Fluent
Meimei Wang
Rep Power: 16 |
I'm modeling aircraft wing by Fluent. I found a problem about drag coefficient Cd and lift coefficient Cl calculation. The sign of Cd and Cl is sometimes minus at the modeling results. But the value is quite accurate. I checked the my reference value setting. They were set reasonably. Anyone has similar problem? And how to solve this problem?
Best regards, Meimei Last edited by Anna Tian; January 14, 2014 at 10:05. |
January 15, 2014, 10:49 |
Alex
Rep Power: 49 |
When you say "sometimes", do you mean that this happens with some of the simulations you perform or does it happen several times with the same simulation?
Are you sure that the direction vector for the evaluation of the force is pointing in the right direction and that your model is oriented correctly? |
January 15, 2014, 10:59 |
#3 | |
Meimei Wang
Rep Power: 16 |
How do I check the direction vector?
Best regards, Meimei |
January 15, 2014, 11:46 |
Alex
Rep Power: 49 |
January 15, 2014, 13:46 |
#5 | |
Meimei Wang
Rep Power: 16 |
January 15, 2014, 14:01 |
Alex
Rep Power: 49 |
A sketch might help.
Anyway, if the main flow direction is in positive x-direction, then a force vector 1/0/0 should result in a positive drag force. You could also show the setup and results of one of your simulations with negative drag coefficient here. Maybe there is something else you are missing. |
January 15, 2014, 15:17 |
#7 | |
Meimei Wang
Rep Power: 16 |
January 15, 2014, 17:52 |
#8 | |
Alex
Rep Power: 49 |
From the previous description of your setup, I concluded that the drag force is pointing in positive x-direction. We definitely need a sketch. Lets assume the main flow direction is in positive x-direction. So to be clear a fluid element travelling with the flow would move from lower x-coordinates to higher x-coordinates. In this case we would expect the force on an obstacle in the flow to be pointing in the same direction (positive x-direction). A drag coefficient should have a positive sign for this setup. The right way to achieve this is with a "force vector" in the same direction as we expect the force on the obstacle. Which means positive x-direction. |
