Error message when model as constant gas
Old   January 14, 2014, 06:33
Question Error message when model as constant gas
Anna Tian's Avatar
Meimei Wang
Anna Tian is on a distinguished road
I'm modeling the 3D aircraft wing. But when I change the material from ideal gas to constant gas and deselect the energy equation, I got the error message as below.
Updating solution at time level N... done.
iter continuity x-velocity y-velocity z-velocity nut time/iter
24565 2.3463e-05 9.2823e-08 5.5400e-08 3.2518e-07 5.0943e-06 0:01:39 50
999999 (..\src\mpsystem.c@1172): mpt_read: failed: errno = 10054
999999: mpt_read: error: read failed trying to read 8 bytes: Invalid argument
MPI Application rank 0 exited before MPI_Finalize() with status -1073741819
The fl process could not be started.
Btw, I use SA model. And everything was normal when I run the simulation with ideal gas and clicking on the energy equation selection.
May I ask what does the error message mean and how to model case in Fluent by constant gas?
Best regards,
Meimei
Anna Tian is offline   Reply With Quote
Ideal vs constant gas model chris12345 STAR-CCM+ 1 January 2, 2013 07:49
model the concentration of toxic gas in a building lily FLUENT 1 December 12, 2007 02:07
gas turbine combustor model - HELP! Phil FLUENT 7 May 2, 2007 07:40
gas turbine combustor model - HELP! Phil FLUENT 2 April 9, 2007 06:05
Shall I use ideal gas model or other? summer FLUENT 6 January 24, 2006 11:43
